Newguys New Old Straight Dolly
  • Please log in to reply
68 replies to this topic
#1 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 04 February 2008 - 09:26 AM
Well boys and girls, i brought the 1850, trailered her on Saturday.
Shes beautiful
Cleaned the shed out, so i can fit both cars in there.
The plan is to take the running gear out of the1 850 and then pull the sprint gear out and get it
fitted up with the manual box etc, then panel and paint.
Wasn't feeling that great yesterday so i only got the radiator out and disconnected most of the cables etc.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
1975 Triumph Dolomite Sprint THE ORIGINAL 16Valve
Project
Discussion
A buried Throttle is a Happy Throttle
#2 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 06 February 2008 - 07:39 PM
Pulled the motor out of the donor this morning and measured bits and peices on the car had shit to do in the afternoon so i didnt even get started on pulling the sprints running gear out. Most likly this weekend.
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#3 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 11 February 2008 - 02:43 PM
Well i got into my wreck this weekend.
Pulled the motor out and stripped it down yet again.
Found all the clutch bits and pieces i need and ordered a new clutch plate cover and bearing from BNT, Parts are for a 2500 So thatl beef the clutch area up a tad.
So hopefully i will get the sub frame changed over this weekend and put the manual box on the motor and put it in and check that my dads drive shaft fits in sweet. Then if it does ill get mine cut down to size.
Hopefully my welder is getting here this weekend so the rust patches will get fixed up in the chassis etc.
Drove another sprint on the weekend, with the same clutch in it with OD on 2nd 3rd and 4th, mines only in 3rd and 4th and shit does it go.
Like 10 times better than an auto box anyday.
Makes it pretty quick to.
So yea Watch this space i guess.
Few pics...
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#4 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 13 February 2008 - 06:05 PM
Pulled the bottom of the dash out in the 1850 shell tonight to get the trans tunnel out and look for any rust.
Ended up pulling the Clutch cylinder off as it had seized up.
Also picked up my new clutch plate, clutch cover and Release Bearing.....
Was not happy with the build quality of the cover, and it was manufactured with damage etc. So i got the higher build quality one instead at no extra charge. As what they tried to sell me was shit.
Also matched up the Master and Slave clutch cylinders.
Any how.... Few pics
Carn't wait to get this beast going!!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#5 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 14 February 2008 - 06:42 PM
Just went and got my Clutch Master and Slave Cylinder
And i paid $37.75.
So im a happy boy, though i have to get a new Hose made.
Where is a good place to get the hoses made? i have the fittings.
Pics of the items.
Posted Image
Posted Image
Project
Discussion
#6 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 24 February 2008 - 10:29 PM
Tried out a few polishing method, on my better timing chain cover.
From this
Posted Image
To This
Posted Image
Posted Image
Posted Image
Project
Discussion
#7 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 24 February 2008 - 10:31 PM
A few crappy Cell Pics of changing the diffs subframes over
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#8 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 24 February 2008 - 10:33 PM
Today i got the Diffs swapped over, have to get some new brake hoses made.
So soo long with nuts being crazy tight and the Shocks bolted in funny.
Switched the cars from one bay to the other and got drenched which ended my day.
Although it took all day to do.
Inspected various bits and pieces.
Any how some decent pics.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#9 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 12 March 2008 - 10:11 PM
Last weekend
Update Pics
Subframe dropped back out of the way so we can heat and remove the bolts and maybe do some more strengthening when he welds
Posted Image
Firewall hole, rust converter.
Posted Image
The Bolts That know how to stay in place.
Posted Image
Chassis Rust Prep at the front
Posted Image
Posted Image
Project
Discussion
#10 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 12 March 2008 - 10:13 PM
Welded up on the outside, chassis
Posted Image
Stitched together from the inside
Posted Image
Primed Outside
Posted Image
Primed Inside
Posted Image
How its all sitting
Posted Image
Posted Image
Cleaned engine bay
Posted Image
Was not to lazy tonight, got the torque converter off, flywheel and the insert that it bolts to.
Also took the sump off, hoping to maybe find the washer i think may have fallen in the block.
I did not find it but i did find 4 small chips of plastic.
I can't think of what they could be??? Maybe something off my water pump or something?
I haven't taken the timing cover off i guess i should have taken that off before i took everything else off as the nut is still in the bottom pully :roll:
Opps
Hope there are some positive comments out there.
Will hopefully get the pulley and timing chain cover off tomorrow.
Then i will put my new cover on and take the block and cover to be matched skim the top of the timing chain cover. then assemble the motor again less the head, and put it back in the car do check i have all the parts, it fits, anything i got to change etc, then pull my dads driveshaft out make sure its a perfect fit and get one made to the same as his.
I Might even have it all read to run so i can make sure the box etc is sweet as a nut before yet throwing more money at her.
Project
Discussion
#11 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 22 March 2008 - 07:16 PM
Well what ive been up to i guess.
Stripped the sump off last week and the oil pump, oil filter, no sign of a wash as of yet.
gave the whole motor a good rub down and blew air down all the water tunnels etc.
Heaps of orange dusty crap came out.
Didn't get stuff all done.
For got to bring the socket set home to take the front pulley off.
Gunna write a list of how im going to go about doing everything.
Motor pics, looks pretty good in there.
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#12 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 22 March 2008 - 07:19 PM
Got the alternator off, timing chain cover off, front pulley etc.
Posted Image
Posted Image
That was pretty straight forward stuff i just didn't have the gear to do it.
Posted Image
I then started messing around with the gear box, cleaned all the build up of oil and dust
around the shifter joint to make the operation alot smoother and easier to move around.
I also cleaned down the gear box more with wd40, and i will degrease it tomorrow.
Posted Image
I then decided to check the oil so i thought id put the box on its side and pull the plug out, so i did this, and the plug was covered in this black oil and i thought thats all was in there.
Posted Image
So i put the box straight and oil came out everywhere, was all a normal oil color
Here some here.
Posted Image
Project
Discussion
#13 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 01 April 2008 - 06:29 AM
Cheers Stu, i am looking at having it professionally rebuilt, i have found a good shaft to use and they would charge me around $150NZ
For parts and labour. I thought would be about right. I might have a crack at it myself, but i don't want it to be a fault.
Anyway here are some update pics.
Painted my flywheel as it was covered in surface rust, then i just removed the paint where the clutch plate sits.
Posted Image
And Mount up on the Block.
Posted Image
Posted Image
Timing cover still removed as i am still not happy with the tensioner
Posted Image
As you can see the block all re hammered back up
Posted Image
And my last decent mission was putting the gearbox onto the motor, i must have had the clutch plate pretty right as she just slide on.
heavy all this on your own though. (Pics pretty overboard as i was pretty happy)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Booster all painted up, looks spanking
Posted Image
HammerRite, Best paint for these jobs i reckon.
Project
Discussion
#14 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 09 May 2008 - 12:44 AM
Well things have been slow latly with almost nothing on the car getting done.
Just ordered a waterpump seal kit finally from aussie so hopefuly ill get that next week.
Plan this weekend is to sat, put the motor in and bolt her up get the electrics working and pull the driveshaft out of my dads car to get one made to the same specs etc.
Motors all together, Had my radiator Flow tested all the channels were nice and clean etc.
So thats a good start
Few Pics
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Converted to the spin on filters
Posted Image
Posted Image
And All filled with
Posted Image
LUBES
Project
Discussion
#15 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 25 May 2008 - 09:54 PM
So Finally i got some work done on the car today.
Did a proper degrease on the engine bay, light sand, undercoated and sprayed with some good orange terrible colored paint.
Better than no paint.
Slide the motor in, mounts all lined up ecept the bolting locations for the gear box which i think are fine i just need to loosen other parts off first no biggy i hope.
Still waiting on my waterpump from Giant Rebuilds
But thats basically it.
Pics
Bay cleaned and painted. Bit Ruff but itl do
Posted Image
Posted Image
Motor and box hanging to be inserted
Posted Image
Posted Image
Posted Image
So Slick
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
So it took me a couple of hours but got me motivated, i can work on the hydraulics etc easy from in the car if i have to.
So progress can only go forward again.
Project
Discussion
#16 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 04 June 2008 - 10:20 PM
back home today
Work starts on this thing tomorrow night.
Some other engine Pics i like
Posted Image
Posted Image
Posted Image
Posted Image
Project
Discussion
#17 NewGuy
NewGuy
  • Members
  • 1048 posts
Well go the water pump in Gasket etc and cover
Also found out why i couldn't get the Box Bracket bolted up, had to be turned around and then the brackets holes were to small so they needed to be drilled out. Spent a couple of hours on her tonight.
But defiantly some motivation1!!!!
Posted Image
Posted Image
Project
Discussion
#18 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 11 June 2008 - 01:04 PM
My Small Wiring mess At the moment
Posted Image
Pic of New Pump, Polished Coil, Clutch hose if you can see it.
Posted Image
Posted Image
Hopefully get the wiring finished tonight.
Project
Discussion
#19 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 12 June 2008 - 11:07 PM
Shes starting to come along
Got the Fuel pump and Fan wired in, Radiator and fan Installed, Relay installed, Checked that the pump and fan would work fine on the wiring i set up with the Starter turning over.
Everything works mint.
Will update tomorrow morning of what is left to be done before turning the key (pushing a button in my case)
Pics
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Just gota sort the dizzy timing out which leads go where, i dunno why but i can not get my head around it!
Project
Discussion
#20 NewGuy
NewGuy
  • Members
  • 1048 posts
Posted 14 June 2008 - 01:08 AM
For any cunts who actually follow this shit thread, i got the bitch started tonight first pop
Epic
Project
Discussion
