NVMPAJ Posted October 14, 2012 Share Posted October 14, 2012 Got my motor on Thursday , pulled out the dead 4M40 and tried out the mid-sump . I even sussed out how to wire the V8 to turnover .its only the beginning but so far so good.i got a Toyota relay fuse box with the intention of running the engine with it ,and keeping the Pajero one for everything else (can't work out how to load pics sorry) heres the future powerplant ..............they are fantastic motors Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 16, 2012 Author Share Posted October 16, 2012 Need to decide weather to make up a steel sump to bolt onto the alloy or bite the bullet and get a rear sump . $400 on eBay delivered would save a lot of hassle , but the fun of making one to suit would be a challenge Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 16, 2012 Author Share Posted October 16, 2012 A better pic of the lower pan and bell housing Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 16, 2012 Author Share Posted October 16, 2012 The Pajero Bell-housing Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 18, 2012 Author Share Posted October 18, 2012 Right I've decided to make the sump, I also have to extend the oil pick up slightly. But I figure if I basically make it the same volume and also use a baffle plate I can't go wrong. Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 21, 2012 Author Share Posted October 21, 2012 Just for anyone interested the Pajero auto is the same as the Lexus ,hence the reason the Lexus bell housing fits the Pajero . Just have to use the lexus bell housing, torque converter ,input shaft and pump then the V8 will connect up to the Pajero . 1 Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 21, 2012 Share Posted October 21, 2012 Cheers for update, im keen to see how this pans out Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 22, 2012 Author Share Posted October 22, 2012 Have been sorting how to wire the pajero auto to work off the Lexus engine , it looks like thanks to a separate computer for the auto I just need to connect the kick down cable , source a Pajero water temp switch that will allow the OD to work when the engine is up to temperature and connect the throttle position sensor (TPS) to the correct wire on the auto computer. Fingers crossed it all works out! Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 23, 2012 Author Share Posted October 23, 2012 Sussed out the ecu hasn't got the 4th plug assume its in Japan somewhere !! .Have been playing about with the sump ,have cut my pickup into two that allows me to reposition it and also make it longer by adding 100mm. I'm thinking about making a plate that will bolt to the upper sump section then bolt my original front steel section to this ,thereby creating a rear sump . I'll post some pics of my devious plan when it starts to look better than lumps of steel! Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 25, 2012 Author Share Posted October 25, 2012 Here's the oil pick in pieces with the extension (in black) the filter I've cut off and turned round so all should fit the new position of the sump .........more pics to follow Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 25, 2012 Author Share Posted October 25, 2012 Well the plot thickens . I've made a mock up of sorts and found the factory sump will hit the front drive shaft. So I'm going to need to build a bit of a hybrid sump that sits off centre to avoid the drive shaft . I wish I had a rear sump set up just to try out. I was hoping to fire up the motor next week just check the wiring etc. I have checked the bores and can see the hone marks which tells me it's either had work recently or has hardly any wear which is great 1 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted October 27, 2012 Share Posted October 27, 2012 badass. would love to see this once it's done Quote Link to comment Share on other sites More sharing options...
AllTorque Posted October 27, 2012 Share Posted October 27, 2012 I'd love to see some pics. Have a read of this. //oldschool.co.nz/index.php?/topic/34643-how-to-add-pictures-to-the-forum/ Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 28, 2012 Author Share Posted October 28, 2012 I tried that one but it was too hard to drive , so photo bucket is it sorry Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted October 28, 2012 Share Posted October 28, 2012 I tried that one but it was too hard to drive , so photo bucket is it sorry Try using photobucket properly, just copy and paste the link with tags around it Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted October 28, 2012 Author Share Posted October 28, 2012 Ok I'll try that .Anyway I've cut out some steel to make a sump . I'll get it tacked together at work and trial it for fitting. The hard bit of posting pics will follow lol Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted November 2, 2012 Author Share Posted November 2, 2012 Have trialed a mockup sump . Seems to fit okay ,will still go for the rare as hens teeth rear sump but will use my home made one in the meantimeThis is the pic of my mockup it avoids the front diff and also the drive shaftThis other pic from google shows the sort of thing I might have to if and when I get the rear one Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 2, 2012 Share Posted November 2, 2012 Nice welds Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted November 3, 2012 Author Share Posted November 3, 2012 Yeah right!! More like tacky tacking . Na the idea is to get one made using my rusty abortion as a template. I tried to weld it to see how good I was , turns out I may have invented gas cutting with a mig welder Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted November 8, 2012 Author Share Posted November 8, 2012 Right I've given my 'sump' to a real welder to get right , in the meantime I'm playing about with a factory toyota fuse/ relay box to use to make the 1uz go ,actually not that easy but it matches up quite well with what I need to make things work. And means I shouldn't have to interfere too much with the Pajero wiring Quote Link to comment Share on other sites More sharing options...
